SC starting problem
OkieSC
12-15-2007 18:23:53
I have a 48 case sc and can't get the starter to work. I have had it checked. The battery has a little over 6 volts. I don't think the start switch work because I checked for volts at the starter when the swithch was pushed and didn't get anything. I tried taking jumper cables and hooked up to battery and clipped on starter and it still didn't do anything. It had just under six volts. Could all this be the battery is to low? Thanks for any help.
greatwest
12-17-2007 23:31:59
 Re: SC starting problem in reply to OkieSC, 12-15-2007 18:23:53
Have a S that did the same thing... disconnect the regular cable to the starter and then try to jump it... my starter cable was very subtlely gounding to one of the clamps that held it in place! hard to see unless you look very closely but a huge draw and the starter would not work well. Good luck, also check how the starter ground to chasis.
OkieSC
12-17-2007 14:27:25
Well I changed the starter switch and cleaned all the places. The battery charges up to 6.8 but when I try to start it it dropes down to .2 and then barely comes up to 6 volts.
Walt Davies
12-16-2007 12:01:16
Sounds like the starter switch could be bad also they don't cost much at any NAPA store just take your old one in to match it up. It doesn't cost much and is worth the time and expense to replace it. then check all connection even at the battery make sure that they are clean. Make sure that the battery post are shiny new not dark or have a hard surface on them. Clean the battery cables out with a knife to make sure that they are clean and right down to the lead or copper. If you have lights on the tractor turn them on then hit the starter button if the light go out then you are not getting enough amperage though to the starter if they stay bright then you have a bad connection between the battery and the starter.
Walt
Gene Dotson
12-16-2007 08:02:52
Check your ground cables at the battery and connection to the chassis. Remove and clean all battery and cable connections.
A fully charged 6 volt battery should check about 6.9 volts with no load. Very possibly a dead battery... Gene
C. Amick
12-15-2007 20:02:08
Try jumping it right at the starter. That should tell you whether or not the problem is the starter.
