Moving a Case
patsdeere
12-13-2007 20:07:51
I just purchased a model L (at least I think) and it is on all steel. I called a local tow company to move it a few miles for me and they showed up and decided that the metal wheels would hurt the deck (I have no clue how a little tractor like that could hurt 1/2 to 3/4 steel plate on their deck).
So my question is what is the easiest way to transport one of these beasts? It doesn't run right now which complicates things slightly .
Thanks.
toomanycases
12-15-2007 17:07:24
 Re: Moving a Case in reply to patsdeere, 12-13-2007 20:07:51
Hi, Where are you located in Calif? I may be able to help you as I have 25' gooseneck with a winch & wooden deck. email me back if interested. Chuck
Engineer20
12-14-2007 19:27:54
Can you rent a trailer some where?
I hand wenched a 6500lb. LA up onto a borrowed trailer. The rear wheels wouldn't turn and the tires were coming off the rims. The trailer was no worse for wear but I thought it was going to kill me!
patsdeere
12-14-2007 19:34:05
 Re: Moving a Case in reply to Engineer20, 12-14-2007 19:27:54
That is how I moved my D that I got. It is just that I don't have the right vehicle (mine weighs about as much as the tractor let alone trailer weight) to tow a trailer right now or I would have gone and done it myself. It seems that nothing ever gets done unless you do it yourself anymore.
bcdave
12-14-2007 17:09:06
By reading these columns, I can see see why my tailer is starting to look old. I didn't buy it to make money but I do use it. I had a 16' 7000lb trailer but it wouldn't carry enough so I traded it for a 20' 14000. I can carry two regular sized tractors now or one big one. I did haul my L home with it. I just put down old 2x10 on my wood deck. It hauled well. I was a little hard on the ramps coming off. It needs short planks to cover the ramps also.
Dave
doug in illinois
12-14-2007 10:48:01
OK, lets think this thru. On steel. Cleats are the issue. I am thinking find some worn out wide radial tires, sawzall them so you can flatten them put, leave a short piece of sidewall on each end, sidewalls are easy to puch a hole thru so you can just the tires over the cleats and baling wire them in place. Just a thought. Also, where are you? Sure someone would be glad to help you out if any old tractor clubs around. DOUG
Backward Thinking
12-14-2007 08:36:56
That guy must make good money and is not very "hungry" for income. His attitude should be that he will haul anything he can winch on. Just throw a few old 2x8s or 2x12s under the wheels and he wouldn't hurt his precious paint. You say the barn was falling down anyway, there had to be something there you could rip off the barn to put under the wheels. There's a difference between use and abuse and he just doesn't know the difference. When I buy trailers or machinery, I buy them to use them so they work for me, not the other way around. That guy just hasn't figured out yet that the trailers you see around that are all scratched up are the money makers. The pretty trailers that don't get used are just money tied up that you could buy another old tractor with!!!
By the way, I know you don't have any flat tires. Do the wheels turn? If its just a few miles and not pavement, then just hook a rope between your tractor and a pickup and enjoy the scenery.
If its pavement, then just travel in the ditch along side the road. If you use another small tractor to pull it, it would be even easier to negotiate the trip. Use a stout chunk of wood or pipe to push it into the new shed. Problem solved and money saved. All you need is a willing helper and just about any 10 year old kid could handle the job.
patsdeere
12-14-2007 16:32:32
 Re: Moving a Case in reply to Backward Thinking, 12-14-2007 08:36:56
The best part was that I offered to use ply or throw some wood under it and he still said no. The best part is that the deck wasn't even painted. :=. If I could tie a chain to it and drag it home I would, but the county would shoot me if I drove it down the main drag. Not to mention CalTrans and the CHP would probably crap a cow if they saw it (since part of the road home is a highway).
I have no ideas if the wheels turn. My guess was that they would since the thing was driven into the barn and parked some 50+ years ago.
The seller suggested getting a local lowboy hauler to haul it (a little overkill I think since the tractor is about 5300lbs not 53000lbs), but that wouldn't work since there is no way on this green earth that I could get the lowboy anywhere near the storage location. Not to mention I would have no way to pull/push it into the storage shed. Oh well, I guess I will just have to figure out plan D.
tuggle
12-13-2007 21:07:46
If they were worried about the kleets, they could of put a board under the wheels. You might be able to take the kleets off.
You may want to buy a 16 foot flat bed for use. You will need it once you get her started and take her to shows.
patsdeere
12-13-2007 21:38:39
 Re: Moving a Case in reply to tuggle, 12-13-2007 21:07:46
At this point I don't think I could get the kleets off since the thing hasn't moved since the early 50s. I even offered to put some plywood down on the bed and the guy just said nope. I could have probably offered to gold plate the truck and he would have still said no. All I wanted was for them to pull it out of a barn (before it collapses on it) and push it into a local rental storage shed place. Oh well, guy drove 45 miles round trip and didn't make a cent. His loss. (And to think that he said that he knew my number if I needed him in the future. HA)
Once I can afford one and have a place to put on I plan on getting something (and something to pull the trailer) but until then it will just have to sit in the barn (aka future home).
LarryNeohiocase
12-14-2007 05:01:20
 Re: Moving a Case in reply to patsdeere, 12-13-2007 21:38:39
If you are close to me I'd be happy to come move it for you... I'm in NE Ohio.
patsdeere
12-14-2007 16:26:30
 Re: Moving a Case in reply to LarryNeohiocase, 12-14-2007 05:01:20
Thanks for the offer, however it would be a long drive to the N. Ca.
Ry
12-16-2007 06:23:36
 Re: Moving a Case in reply to patsdeere, 12-14-2007 16:26:30
Might try the first guys competitor -
