vac pto seal
steven in tn
12-13-2007 16:50:12
does any body have an outer pto seal # from napa or carquest. also the bearing and race?
for a 50 vac THANKS
M5G
12-14-2007 11:26:35
 Re: vac pto seal in reply to steven in tn, 12-13-2007 16:50:12
Also:
Federal Mogul No. 473215 Bearing Seal
size: 1.375 x 2.374 x 0.312
Use Speedi Sleeve on shaft: 1.371-1.377 to prevent any wear on shaft to leak by seal. # 25591 3423.
3 Bolts get you to seal and you can install speedi sleeve and seal.
olddog
12-14-2007 03:35:33
I put 2 - CR 13738 seals back in mine. Didn't change bearing.
Paul f
12-14-2007 05:26:04
 Re: vac pto seal in reply to olddog, 12-14-2007 03:35:33
CR 13739 also work and have two sealing surfaces instead of one in 13738 see profile on the links below
Link
