replace lower radiator hose on LA
toomanycases
12-12-2007 17:53:29
Hi, Is there a easy way to get the lower hose off the radiator short of taking off the radiator? Mine is leaking a steady stream now. Was just dripping occasionly before. Suggestions would be appreciated. Thanks, Chuck
bradley martin
12-13-2007 04:38:27
 Re: replace lower radiator hose on LA in reply to toomanycases, 12-12-2007 17:53:29
As DCase says, warmer temperatures make it easier. Soak new hose in boiling hot water for 2-3 minutes before trying to install. Also, grease on the inlet nipples help.
JGarner
12-13-2007 05:17:20
 Re: replace lower radiator hose on LA in reply to bradley martin, 12-13-2007 04:38:27
I always spray the inside of my hoses with WD 40 before intalling. That way I don't get any heavy grease into the radiator acidentally if it were applied too liberally.
Grease or WD 40 will make the hose a lot easier to remove the next time it needs to be replaced too, although I usually split mine with a utility knife to remove the lubrication still makes the hose come loose easier.
DKase
12-12-2007 20:24:48
Off is easy, on gets more interesting. With a new hose I have gotten them on by doubling them up and pushing all the way onto one side, and then back onto the other. Warmer temps help. DK
