SC Carb Tuning
J. Horn
12-11-2007 17:58:33
I have a rebuilt Zenith 61 on a 48 SC. Can"t get carb tuned. Tractor won"t start. Will fire with starting fluid but wont catch. Thinking tuning may be wrong. Is there a certain # of turns for screw adjustments? I replaced the manifold gasket,new filters, plugs, wires, etc. Thanks
J. Horn
12-14-2007 16:07:05
 Re: SC Carb Tuning in reply to J. Horn, 12-11-2007 17:58:33
The Carb is a 9667A.
J heitkemper
12-12-2007 18:33:35
Intake and exhaust manifold has a hole and thewrefore are sharing gasses ,,
J. Horn
12-12-2007 16:28:35
I replaced the manifold gasket, which was bad. The tractor would run before the carb was rebuilt, but w wouldnt run unless the choke was about 3/4 closed. and even the it ran rough.
C. Amick
12-13-2007 09:18:20
 Re: SC Carb Tuning in reply to J. Horn, 12-12-2007 16:28:35
If that's not the correct carb for the tractor,the jet might be too small for it to run properly.
C. Amick
12-13-2007 09:52:50
 Re: SC Carb Tuning in reply to C. Amick, 12-13-2007 09:18:20
Below is a link to a Case SC carb up for auction on Ebay. The seller says it is a "667A, but I think he misread the number. The correct number is 9667A. If the body is the same size in the carb you have, you might be able to put a 9667A rebuild kit in your carb and get it to work???? Someone on the forum should know the answer to this.
C. Amick
12-12-2007 09:13:56
Did you have the tractor running with that carburetor on it before you rebuilt it? A Zenith 61 is not a familiar carburetor model number to me.
Tom Railsback
12-12-2007 07:27:47
I'd also check to see that the valves are set correctly (.010 cold). My C Case wouldn't start or run well until I did this.
J Heitkemper
12-11-2007 19:49:40
What is the history of the tractor ? Has it been running poor / indicating need for a carb rebuild ? ... May be the intake and exhaust manifold are rusted /rotted / Burned thru so that the intake is sharing gasses and therefore not getting the updraft from the Carburator ...EVERY SC ON THIS PLACE HAS HAD THIS PROBLEM , poor design in my opinion.. Check for this condition and if that is the culprit , IT CAN BE REPAIRED BY MANY WHO MONITOR THIS FORUM .. BEST WISHES , JIM
LenND
12-11-2007 19:09:39
Most carbs if you turn the adjustments all the way---just snug. Then turn them back out about one and a half turns should be close enough for the motor to start.
