511b fails to turn over
Jeremy Conaway
12-11-2007 06:08:24
This summer I bought a '58 511b because it was a price I couldn't pass up. It ran quite well, even though it was missing on #3 cylinder (plug wire???). Anway, it's been sitting, waiting for me to get the time to play with it so I went outside a while back and tried to start it. Nothing. Battery is charged but the solenoid just clicks and the starter doesn't make a peep. Took a pair of pliers and tried to jump them across the solenoid terminals but still nothing. Removed the starter and connected it to a battery charger and it spins up. Cleaned up the mating surfaces of the starter and flywheel housing, re-installed it--nothing. I would suspect the solenoid but figured if I crossed the terminals like I did it should have spun up. Any suggestions?
GeoM0
12-12-2007 06:00:21
 Re: 511b fails to turn over in reply to Jeremy Conaway, 12-11-2007 06:08:24
I would suspect the connections in the solenoid.
Pliers should have work.
Jeremy may be right, cables almost broke.
I removed the cap on the solenoid and cleaned washer and contacts 2 weeks ago, found that the brushes in the starter was stuck. Might be your problem, when you removed the starter it shook them loose.
DKase
12-11-2007 06:32:56
Check the voltage at the starter terminal when trying to start. If none or low follow the wires back till you get something. Good Luck DK
Jeremy Conaway
12-11-2007 06:41:58
 Re: 511b fails to turn over in reply to DKase, 12-11-2007 06:32:56
Thanks, DKase, I"ll have to do that. If I recall correctly, there was voltage but will double-check it. If so, should I remove the brushes and make sure they"re not cruddy?
