Case 580 ck
Duby
12-10-2007 21:14:16
I just bought a case 580ck, don't have any idea what year it is.(1970's ?) When the tractor is cold the unit won't move at all. After it warms up, and shuttle is in fwd or reverse, it takes a while to get moving. It seems to have a little power, but not enough to move the bucket while on the ground and any pressure on it. The engine has recently been overhauled and the mechanic said the transmission looked pretty good. any ideas?
Thanks
Duby
duby joe
12-13-2007 18:57:09
 Re: Case 580 ck in reply to Duby, 12-10-2007 21:14:16
I pulled the filters and will replace tomorrow. I have been reading the thread about case 580 clutch slippage and my symptoms are almost exact. Mine takes a bit to engage and then when I try to push dirt, it surges and I have to raise the bucket then it will move. I think my biggest problem is the lever for the shuttle. there isn't any type of stop or indent for the lever so you have to be very careful in finding the sweet spot. Does anyone know of a drawing so I can get something fabricated to alleviate this problem to start with? one question, my manual doesn't reflect where the fluid level should be on the dip stick for the torque tube (fwd of shifter). Mine is almost 1.5" above the ring on the stick.
What type of oil do you recommend for the engine.
I also bought a 5 of case fluid and will replace all of my fluid with case. Any idea where on the engine/tranny I can get numbers to id the year model?(my manual doesn't cover that either) Thanks so much for your help. This is the best forum I have ever seen.
Duby
Duby
12-12-2007 18:50:04
 case 530ck in reply to Duby, 12-10-2007 21:14:16
Are they in the open to get to? Thsnks
Duby
jim in north texas
12-11-2007 05:28:26
Change the hydraulic filters. there probably wet
