SC Carb Rebuild
J. Horn
12-10-2007 19:40:53
Whats the best way to get stuck and stripped jets out of the carb without breaking anything in order to replace them? Soaked it in cleaner, put WD40 on it and they still wont budge. Thanks
patsdeere
12-10-2007 21:17:05
 Re: SC Carb Rebuild in reply to J. Horn, 12-10-2007 19:40:53
I know this may seem like the easy way out (and it is), but I had a carb that was completely rusted up. I was only able to get 2 screws out of it (total). I sent it off to a guy in Maine and he made it look and work like new. The best money I have spent in a long time.
nark ssergent
12-10-2007 19:59:55
Try soaking it with PB Blaster spray oil. It works a lot better than WD 40 which I believe is good for house door hinges only. If you can get to it can you drill it out and use a easy out or chisel on the edge to turn it. I would see a new jet to know how big to drill or if you can even drill.
