power steeringr
sod buster
12-05-2007 20:43:10
does anyone know if there is suppose to be any end play in the worm gear shaft on the steering gear box.?the model is a 1030 comfort king.
cahess
12-06-2007 03:51:27
 Re: power steeringr in reply to sod buster, 12-05-2007 20:43:10
Good advise from mEl. Might add if you are having trouble with steering feeling like it wants to lock up you need to check u joints. At this this age of there life they are probably dry if never serviced. One at gear box is a n eedle bearing an can be replaced. Others you can disamble an grease. Least that is how my 930was. Needle bearing u joint is avaible from napa an probably from Case.
mEl
12-06-2007 03:07:40
Go back to page 3 and look at 730 steering problem post.
mEl
12-06-2007 03:07:13
Go back to page 3 and look at 730 steering prob lem post.
