Replacement Headlamp Reflectors from China
C. Amick
12-04-2007 09:25:59
Don't do what I did over the weekend! I have a new 7-inch chrome headlamp reflector that I ruined. It had a few smudges on it, so I thought I would polish it a little with some automobile car wax/cleaner. It immediately ate the chrome coating off the reflector on contact. I was not a happy camper. Guess I have to order another one.
Steve_Md
12-05-2007 03:58:41
 Re: Replacement Headlamp Reflectors from China in reply to C. Amick, 12-04-2007 09:25:59
Believe it or not, I have had great success using the standard kitchen aluminum foil! Here is the procedure: Using a matching sturdy spherical object, (ie. ball- not a soft one), form-fit the foil with the shiny side against it. Don't be concerned with a few wrinkles that remain after the form-fit. Apply contact cement or weatherstrip adhesive to the reflector being repaired and mate it with the foil using the ball as backing. After a few minutes, remove from ball and carefully form-fit the aluminum smoothing out the wrinkles with your fingers using a clean soft cloth. Cut the center hole and outside diameter with a utility blade. Compare the light output against a good one with the same voltage/candle power and you won't see any difference with your eye!
Klyde
12-04-2007 17:36:10
I think that if the plating came right off with chrome polish it was probably silver plate just like the orginals.
SDLars
12-04-2007 12:01:08
I've had good success with "chrome" paint. I even used it on the park lamp of one of my old cars and with six volt lamps, you can't tell which one is painted and which one is chrome.
C. Amick
12-04-2007 12:24:16
 Re: Replacement Headlamp Reflectors from China in reply to SDLars, 12-04-2007 12:01:08
I was thinking about trying chrome tape. Is there any particular brand of chrome paint that you have used that is better than others? Re-chroming was way too expensive ($75 to $100 each)!
JGarner
12-05-2007 06:35:56
 Re: Replacement Headlamp Reflectors from China in reply to C. Amick, 12-04-2007 12:24:16
At that price this may be a viable parts supply project for CAMBOTED. HE can probably get you "better than China or India" parts with real chorme or nickle plated parts for way less money than just a rechrome job. As well any of his profits get plowed back into a good cause. Think I will post a message for him concerning this in case he doesn't this post and the response string, what do you think??
C. Amick
12-05-2007 07:52:51
 Re: Replacement Headlamp Reflectors from China in reply to JGarner, 12-05-2007 06:35:56
The 7-inch Chinese reflector was only $14.00. If the coating came off with automobile wax though, I wonder how long it would have lasted on the tractor?
