International 3514 Industrial
Brad-MN
12-03-2007 14:00:35
Hi, I am in need of some motor parts for an Int"l 3514 Ind. tractor. I believe it has the C-175 gas motor in it. I am in need of a good camshaft. The gear on mine that runs the oil pump/distributor drive is totally destroyed and it doesn"t look like the gear comes off the cam, it looks like it is cut right into the camshaft. Any help would be appreciated, especially if someone knows of a web site where I can get more information on this particular tractor. Thanks
Brad
L.C.Gray
12-04-2007 17:43:52
 Re: International 3514 Industrial in reply to Brad-MN, 12-03-2007 14:00:35
I have a cam out of a 300 U which used the C-169 engine. I believe the C-169 was virtually identical to the C-175 besides bore and stroke.
It has had a past repair job on the keyway, but was from a running engine.
Have cam, thrust plate, lifters, cam gear and all the other front accessory drive parts that are headed to junk.
If you can't find one better or closer let me know. All it'll cost you is whatever it costs to ship it.
BasketCASE
12-04-2007 09:17:17
International's industrial division was sold off long ago to Dresser Industries, which was recently acquired by Komatsu, I believe. Parts for those tractors are available through those dealer networks. Although, you may be able to get engine parts through a local Case IH dealer. Have you checked there?
