case vac 12-volt conversion
Jim Phares
12-03-2007 13:46:53
looking for info on necessary components to convert case 1952 vac to 12-volt system
BarryfromIA
12-03-2007 20:29:29
 Re: case vac 12-volt conversion in reply to topdog, 12-03-2007 13:46:53
An alternator puts out more amps than a generator. Pretty big deal on a chore or short run type jobs, and cheaper to find than a generator type system.
Jim McVay
12-03-2007 20:05:03
 Re: case vac 12-volt conversion in reply to Jim Phares, 12-03-2007 13:46:53
I used the 10si Delco alternator. I installed a key switch to start it with the use of a starter solenoid instead of the foot switch and ran the on wire to the coil and the acc wire to the alternator to energise it and allow it to shut off with out using a diode. I used an internal resisted coil. Not just like CASE made it but it sure works a lot better if you want to depend on it.
Older n Old
12-03-2007 17:52:25
Why would you want to?
GeoM0
12-04-2007 04:45:17
 Re: case vac 12-volt conversion in reply to Older n Old, 12-03-2007 17:52:25
My
51 VAC would start most of the time (in the late 50's) in the summer with a NEW 6V battery. We started it in the winter with a hand crank, would start with one or two pulls.
It is really great to set in the seat and start it anytime.
It is a work tractor, not a show tractor.
BarryfromIA
12-03-2007 15:11:03
 Re: case vac 12-volt conversion in reply to 4435, 12-03-2007 13:46:53
Look in the articles section. I used the one for an M that uses a delco 10si. I modified it to use a solenoid
