Calcium or weight box?
Bill64
12-02-2007 20:20:58
I am replacing the tires and one rim on my '56 310 Utility w/front end loader. Tractor will be used for mowing and light landscaping. Can I get away with making a weight box that I can lift on the eagle hitch for counter-weight or should I pump in the salt. Really don't want to if I can get away with it concidering the new tires, tubes, and rim.
Thanks,
Bill
Harry J. Case
12-03-2007 20:02:19
 Re: Calcium or weight box? in reply to Bill64, 12-02-2007 20:20:58
Hey Bill How about using wind sheild washer fluid plus a wheel weight to make up the difference in the weight of calcium cloride? Won't destroy your new rims. Harry Case, Allis, Moline nut
Harry J. Case
12-03-2007 19:59:17
Glenn F.
12-03-2007 10:05:11
You'll have to decide, but I can't imagine a loader tractor without the rear tires 80% full of fluid. CC is excellent ballast. You just have to "keep an eye open for leaks".
Glenn F.
Squirrel
12-03-2007 09:08:35
Look into Rim-guard if you decide on the Calcium. It is not cuastic to your rims and has just about the same weight/lb as the Ca. I don't know how it compares on price though.
daveleeander
12-03-2007 05:16:46
 Re: Calcium or weight box? in reply to ROYBOY, 12-02-2007 20:20:58
I would use the old anti freeze instead of the calcium chloride. It won't damage the steel like the calcium chloride will if it leaks. That what I have in my 1212.
Dave
bradley martin
12-03-2007 02:22:47
Personally, Bill, with the front end loader on the tractor, I would put in the calcium chloride. Someday you will not have that counterweight on the eagle hitch when you decide to make a quick lift of something and bad things will happen.
