SC engine troubles
SDLars
12-02-2007 08:29:44
I got my SC all wired up last night and decided to crank it over a bit with the starter before putting the plug wires on. Everything worked fine for several revolutions when suddenly I heard a noise (clunk?) from what sounded like the front of the block and the engine stopped dead like it had run up against something fairly solid but not totally so because when I turn it with the crank, it feels like it has some give when I run up against whatever it is I run into. I can turn it backward. I have been turning it over with the crank when I've been working on various stages of the engine disassembly and assembly, no problems. I replaced the governor because the mountings had been modified and am thinking it may be something tied to that and the cam? Before I start tearing it all down again, I thought I'd see what you fellows think. I was ready to put the hood on and fire it up, but not now!
SDLars
12-02-2007 13:42:24
 Re: SC engine troubles in reply to SDLars, 12-02-2007 08:29:44
Found the problem. My governor is a mess. Must have put something together wrong. Not sure how.
