Eagle top link
Kirk in Oregon
12-01-2007 21:18:49
I wrecked the top link of eagle hitch on my 611B! Last year I acquired an original Case subsoiler shank which actually works pretty good. Except when I forgot about a really big rock that I actually knew was in the field; stupid me! Compressed the link and broke the side out of the threaded adjuster section. So, the question is will any Eagle top link work on 611b or is this model specific? This tractor is only Eagle hitch I have been around; my others are straight drawbar. Thanks for any advice! KL
JGarner
12-03-2007 07:53:21
 Re: Eagle top link in reply to Kirk in Oregon, 12-01-2007 21:18:49
The 500B/600B, 530 and 630 all use the same top link. As well the turnbuckle, (cast center section) and implement end are the same as a VAC and probably SC. I made a top link for my 630 from a VAC top link. I torched off the very end of of the VAC link half way up the mounting hole. A friend machined a small peice of tube for the top link conversion. I measured the thickness of the VAC end, hack saw cut 2 slots to about half way down in the tube and torched in on an angle so that the piece fell out. That left me a weld bevel. I slid the VAC end piece in with the 630 mounting pin in place in the tube and tack welded the fabricated tube piece to the VAC end piece. I pulled the mounting pin out and then welded it all together. I also built up with weld metal so I could grind it off to look the the original forged piece.
If the tractor mount end of your link is still OK then all you need to do is find a VAC top link and take the bottom end off and screw yours in.
watsosngotit
12-02-2007 06:06:05
You might check ebay. There are always origional top links on there. I think you will be happier with an origional rather than a run of the mill replacement.
Glenn FitzGerald
12-02-2007 04:13:53
It's always nice to have the original link, but yes, a generic one will work just fine if it is the right length and will clear your bracket at the connecting point. I have an original and a generic for my SC and DC. The generic, (bought at Fleet Farm) was a couple inches too long. I shortened up the adjuster a couple inches and it works just fine.
Glenn F.
