Value of a VAC
deano
12-01-2007 18:20:32
What do you think a VAC with a stuck motor is worth? Otherwise condition isn't to bad, missing belt pulley but everything else is there
Deano
12-02-2007 07:42:02
 Re: Value of a VAC in reply to deano, 12-01-2007 18:20:32
Sorry Tim, I'm looing at buying too. It's a 2 wheel tricycle, eagle hitch , bad paint, metal would be a 6-7 on scale of 10, no visible cracks in castings, tires are junk. Haven't checked S/N but think it's a 46
watsosngotit
12-02-2007 15:33:34
 Re: Value of a VAC in reply to Deano, 12-02-2007 07:42:02
It can not be a 46 with eagle hitch. This did not come out until 1949. Remember subtract 4 from the first two numbers of the serial number to find the year. I don't recall you mentioning the condition of the engine, complete, stuck, etc. This would help in giving you an idea on price. Also keep in mind that the origional top links are worth around $100. If you have one of these it will deffinatly help the price. What are your future intentions? If you plan to part it out, it is not worth as much as you can get out of the individual parts. If the engine is stuck I would hate to put much more than $250 into it. If the engine is complete, not suuck, and would likely run $400-$450 would be a good price. Remember they are a simple little tractor and there are lots of them availiable.
TimBinWV
12-02-2007 05:37:23
I'm interested if you're close to WV..zip 25571
Glenn FitzGerald
12-02-2007 04:05:30
Just from your limited description I'd say $250.
Location, condition of tires, engine block cracked, exhaust manifold cracked, hydraulics or eagle hitch, wide or narrow front, condition of sheet metal...?
Glenn
Matt L
12-03-2007 11:39:20
 Re: Value of a VAC in reply to Glenn FitzGerald, 12-02-2007 04:05:30
Pics would help too -
