511b, not turning over
Jeremy Conaway
12-01-2007 13:16:01
A few months ago I brought home a 511b because it was being sold for a price I couldn"t resist. At the time, it started and ran ok, but now when I go out to start it it won"t even spin, even if I jump it from a truck. Crossing the two poles on the solenoid with a pair of pliers didn"t do anything, so I took off the starter and hooked it up to a battery charger. It does spin when doing so.
Can someone tell me the likely problem? Is the solenoid (which looks ancient) suspect? Thanks in advance.
caseman-d
12-02-2007 20:43:33
 Re: 511b, not turning over in reply to toolz, 12-01-2007 13:16:01
Pull the starter and make sure it's not stuck. While starter is of turn engine over with pry bar to make sure engine will turn over. When you have starter off that would be a good time to check the starter.
caseman-d
Jeremy Conaway
12-11-2007 06:10:17
 Re: 511b, not turning over in reply to caseman-d, 12-02-2007 20:43:33
Thanks for the reply, Caseman. I did both of those things when I took the starter off a few days ago. Flywheel is not stuck and the starter spun up when connected to a battery charger.
