pulling with a power shift
Fran Kopta
11-29-2007 16:20:01
anybody out there pulling with a case powershift.have a 1070 pwershift and abig crank 504,was wondering if powershift would hold up or if there was any way to beef it up to help out. thanks, fran
casefarmer
12-01-2007 15:11:55
 Re: pulling with a power shift in reply to Fran Kopta, 11-29-2007 16:20:01
I have an 1175 8 speed that we put a 4 inch turbo, lazercut injectors and run water/methanol injection. It makes around 500 horsepower running 3000 rpm. We use the stock clutch and outboard planetary rear(bullet proof) and never had any trouble.
BarryfromIA
11-30-2007 16:36:49
 Re: pulling with a power shift in reply to Joe (Wa), 11-29-2007 16:20:01
Elmer's repair out of Kansas has some experience with 730 rear end bolted to a 504. I have seen them pull. It's a a bolt in deal mostly.
turbo
11-29-2007 19:22:38
We pull with a 2290 PS in out of field 10,000# to 12,000# classes. It has on more pair of plates in C-2 and C-3 than a 1070 and a much heavier C-1. We pull in 3rd range and advance to 3rd in powershift. Stayed together all season shifting down under load. Usually just once to 2nd. We have a balanced big crank 504 in front of it turning 3000 rpm with stock injection pump, working remotes, 3pt and PTO. The balancing was the best money we spent. We dyno it and the pto slipped at 250HP and the engine had only dropped 100 rpm. Defeated a lot of green ones and usually placed. Placed 1st several times. Had a lot of fun this past summer.
triplerange
11-30-2007 05:12:33
 Re: pulling with a power shift in reply to turbo, 11-29-2007 19:22:38
Sounds like a good machine, but didn't 2290s come with 504s from the factory...or am I thinking of the 2294s?
1070 had the 451 and far less beafy rear end...so In my opinion would not handle more hp.
DKase
11-30-2007 10:39:36
 Re: pulling with a power shift in reply to triplerange, 11-30-2007 05:12:33
2090, 2290, 2094, and 2294 had small journal 504's, 22's had turbo, most 20's did not.
