504 Heads
TravisM
11-29-2007 10:03:44
Will the 504 head fit on a 451 out of a 1270
If not what has to be done for it to work. What type of injectors do the direct inject 451 heads have.
Thad
11-29-2007 14:55:09
 Re: 504 Heads in reply to TravisM, 11-29-2007 10:03:44
Well Travis i always figured i wouldnt do it myself. I have measured in the past the bore on a 451 is 4.375. The 504s valves are 4.380 outside to outside or so. You would have to clearance the sleeve for the valve to clear and enlarge the valve reliefs in the pistons. The 451s and early 504s have a small pencil type injector. The later 504s have a larger body type injector. Hope this helped Thad.
Lamont
12-01-2007 21:55:42
 Re: 504 Heads in reply to Thad, 11-29-2007 14:55:09
Thad, I thought of another question. How many HP can I realistically expect out of a 1070 without adding a turbo? It's pretty stout already at 118 hp. Can I get much more? If so, how?
Lamont
11-30-2007 21:15:02
Hey Thad! How's it going? Way off the subject here, but do you have any rear wheel lugs for a DC Case laying around? I'm looking for a dozen of 'em. These just squeeze that wide rib on the rim. That may be the only kind for a DC. I don't know. It's for a 14 X 38 rim if that makes any difference. Thanks for any help.
Thad
12-01-2007 09:25:50
 Re: 504 Heads in reply to Lamont, 11-30-2007 21:15:02
I should have a bunch around. I will round some up monday and get ahold of you to send them. Weve been real busy in the shop lately so i dont get much time to play around on the computor like i used to. Thad
DKase
12-01-2007 04:35:35
I have dozens if Thad does not. Email if I can help. DK
