Starting a 2670 when cold
kirk in ks,
11-29-2007 05:41:47
I didnt know that starter fluid would ruin the engine on this 2670 I couldnt get it started and it seems like the only way to get it started, and i didnt know it would ruin seal's and other thinghsd so maybe i wont try it again,
as i dont wanna ruin the engine after i just got it not too long ago,
kirk,
Dairy farmer in WI
11-29-2007 19:06:35
 Re: Starting a 2670 when cold in reply to kirk in ks,, 11-29-2007 05:41:47
yeah no kiddin'. i have a 970 Powershift. i have a block heater in it and haul manure with it since it's the only one with a good sealed cab. i plug it in over night and usually don't use it until about 4 pm. pops right off but i let it run at least 10 minutes to let the rear end warm up. if you push that clutch in when the hyd. oil is cold... it kills the tractor! always let a powershift warm up at least 5-10 minutes. and as you know, don't get too happy with the either
kirk in ks,
11-30-2007 04:49:33
 Re: Starting a 2670 when cold in reply to Dairy farmer in WI, 11-29-2007 19:06:35
i t wasnt that cold when I used the ether on it ,
it was about 45, or 50 degrees in the afternoon and the batteries were getting low so i shot some ether in the intake and it took off ,
but it wasnt really cold or anything that morning when i tried to start it and the back
lift cylinder is leaking hyd fluid out the bottom seal ,, old i guess, so ill redo that too and then the hyd fluid wont get low, other otherwise ,,, everything is ok on it starts right up everytime and no problem's on anything,
Im not using ether to get it started just that onetime , and when i was out ttrying it the 3rd gear powershift was a little stiff so i think the fluid was a little low other than that everything is ok,
John Saeli
11-29-2007 06:25:41
Hey Kirk; If you don't need to use it, it's best to leave it set. If you need to use it, install a block heater. The Case Power Shift also does not like cold weather. If you need to use it when cold, best to let it warm up.
Ande
11-29-2007 09:53:46
 Re: Starting a 2670 when cold in reply to John Saeli, 11-29-2007 06:25:41
Kirk,I agree with John, but if you have too,also turn the engine over several times with the stop cable out,this way will give enough oil to get up into the engine and to the turbo and everything else.Also maybe a magnetic heater for the trans resivoir.But like Johns says,if you dont need it,dont start it!Just my thoughts.
Ande
