S DC Water Pump Seal
Tractorfellow
11-27-2007 17:07:20
Is there a source out there that supplies the seal used in the "S" & "DC" water pumps? Or even rebuild kits? I have not been able to locate any source other than CNH. The seal is about $50 from them. Or is this seal used on any other type tractor. I know it is the same seal as a International TD 15 Dozer has in it.
Tractorfellow
11-28-2007 19:35:43
 Re: S DC Water Pump Seal in reply to Tractorfellow, 11-27-2007 17:07:20
I appreciate all the replies, I have the pump apart and was looking for the seal, the rest looks OK. The WPK195 kit I think is for the A.C. "B", "C", "CA", etc. The WPK 119 Kit is for the "WC","WF,"WD",etc. Seals from both kits will work as they appear to be the same. It appears a lot of water pumps used this seal. It should be be available somewhere by the industry number.
Kevin Meier
11-28-2007 14:52:46
I get $100 to rebuild a dc water pump. There is some machine work involved I turn the mating surface down to fit a ceramic instead of riding against the cast like oem. I also vacuum test all of my water pumps for leaks before they are boxed and warranty them for 1 year.
C. Amick
11-28-2007 09:32:28
I've heard that rebuilding an "S" Series tractor water pump is not that easy. A friend of mine got his rebuilt through O'Reilly Auto Parts for around $65, but that's been a few years ago.
CHinNY
11-28-2007 05:55:00
I have the WPK-195 kit My supplier no longer carries them and they are more money then some else stated i get $80. for it. I believe i have one or two left.
DKase
11-27-2007 18:20:10
Don Livingston has the DC seals. Last ones I got were under $15. The shaft will most likely be rusty and the water is leaking under through the seal. I grind the rust all off, build them up with brass and turn them down in the lathe. If you cannot do, or have someone that can do this kind of work you might be better off getting a new one for the $120. I have never had to work on an S water pump so Kevin has better advice there than I do. DK
Kevin Brambrink
11-27-2007 18:08:40
I put a kit in my S case waterpump.
the number that is on the box is WPK-195.
I think it is the same as a wc allis,and paid 60.00 for the whole kit including bearing. Hopes this helps
