Case VAC clutch linkage
Charlie North
11-26-2007 11:06:12
The clutch linkage on my Case (VAC5371159) apparently came loose inside the bellhousing.
When looking at the parts manuals available online, the linkage is more like the VAI setup than that shown for the VAC. (It is a straight rod from the pedal to where it enters the bellhousing.)
Did Case sometimes interchange parts between the two models?
It is a tricycle setup with two front wheels. This makes it a VAC-12 correct?
Thanks,
Charlie
mj
11-28-2007 09:50:58
 Re: Case VAC clutch linkage in reply to Jerry W, 11-26-2007 11:06:12
VACLee said: (quoted from post at 22:47:52 11/26/07) MJ, I tried to email you a while back about the front bolster but never heard back. You still want to sell it?
Yep, it's not doing anyone any good right now. I'll look in the spam trap for your e. third party image
Charlie North
11-27-2007 15:26:55
 Re: Case VAC clutch linkage in reply to Charlie North, 11-26-2007 11:06:12
Thank you all for your help. A farmer friend warned me to hook the frontend high when splitting to avoid tipping. I appreciate your helpful advice!
GeoM0
11-27-2007 05:48:43
I had the same problem. it has been awhile and I do not remember what happened. It was not a big deal except for splitting tractor, I had just replaced clutch disk.
mj
11-26-2007 18:31:24
 Re: Case VAC clutch linkage in reply to Caseman 2, 11-26-2007 11:06:12
VACLee probably hit the nail right on the head :?....just pull her apart and replace the rod.
third party imagethird party image
Here's a link that might be of some help:
Link
VACLee
11-26-2007 20:47:52
 Re: Case VAC clutch linkage in reply to mj, 11-26-2007 18:31:24
mj
11-28-2007 10:01:48
 Re: Case VAC clutch linkage in reply to VACLee, 11-26-2007 20:47:52
Ooooops! I guess you've got my e addy but it's on on this one just in case you lost it.
VACLee
11-26-2007 15:24:14
The clutch linkage is the same for all the models including the VAI except the VAC 14, VAIW, and the VAO. They had the platforms mounted lower and had pivots mounted on the torque tube. They are also diferent from each other, except the later VAO 15 which appears to be the same as the VAC 14. There isn't much to come unhooked unfortunately. The linkage has the ball made on the end. More than likely the rod either broke, or has worn thru the fork. It is also possible that the fork has worn or broke at the pivot ball. Good luck. You will have to split tractor to find the problem.
