Need a VAC generator
jal-SD
11-26-2007 06:40:09
Does anyone have a spare VAC generator? My armature is shot & parts guy don't think he can find a new one or a generator. The only apparent option is to convert it to 12V w/alternator & I don't want to do that very bad. (My $0.02 worth. jal-SD)
mj
11-28-2007 09:35:31
 Re: Need a VAC generator in reply to Aaron Ford, 11-26-2007 06:40:09
Walt Davies said: (quoted from post at 12:58:21 11/27/07) Go to moc.tlib-ulav and they have everything that you need.
Walt
Walt - Are you sure about that URL? I can't get it to work third party image
Walt Davies
11-27-2007 10:58:21
 Re: Need a VAC generator in reply to jal-SD, 11-26-2007 06:40:09
Go to moc.tlib-ulav and they have everything that you need. Walt
BLR
11-26-2007 21:58:04
I had a similar dilemma a few years ago and after some thought I removed the generator and all the related 6v system stuff and put it in a box for for possible future return to originality. Then replaced the generator with a rebuilt internally regulated alternator, battery, coil, light switch, and lights. I made the top bracket from an old chevy truck bracket(curved)and fabricated the bottom bracket from scratch. All of which was fairly easy. The wiring tips on this site were also very helpful. I was reluctant at first, but the tractor starts much easier, the lights are brighter, and I won't change back.
mj
11-26-2007 18:47:33
I've got 3 or 4 that will rebuild. Shoot me an email.
Klyde
11-26-2007 17:25:23
give John Saeli a call, he got all my nos armatures and i think there were some in there that would work on a vac.
Gene Dotson
11-26-2007 13:05:34
I have 2 tractors that have 6 volt generators and regulators from Early 50's Ford trucks. They are positive ground with the wide pulley for the wide belt. Also positive ground. Only have to bend the bottom bracket a little and fabricate a new adjusting bracket. I mount the regulator in the toolbox... Gene
Paul f
11-26-2007 07:26:20
Check with a starter/generator shop..If you want to go with a more modern generator and regulator (as opposed to the cutout type) he will probabaly have one lying around.
TimBinWV
11-26-2007 07:19:22
Seems to me there's one in the shed...What's one worth?
TimBinWV
11-26-2007 07:31:18
 Re: Need a VAC generator in reply to TimBinWV, 11-26-2007 07:19:22
I was mistaken,I must have junked it...Sorry!
