480CK Carb Adjustment
480CK
11-26-2007 04:29:09
I have to have the choke pulled almost all the way out to keep the engine running smoothly. I will adjust the power jet until the choke is not necessary and then tractor will run fine for a while. Then, after a little work with it, I start having to have the choke pulled out again to keep it running. Any suggestions? Is the float needle getting stuck as the engine warms up possibly? I don"t want to tear the carb down until it"s necessary and I have exhausted all other possible reasons for this. Thanks.
