cranky engine on a vac14
jerrys
11-25-2007 21:28:26
i have a case vac a little new to classic tractors but alway loved then i am wondering if they all get cranky in cold weather or is she needing a tune up?
jerrys
11-28-2007 19:55:34
 Re: cranky engine on a vac14 in reply to jerrys, 11-25-2007 21:28:26
i gave her a little tune up and checked a few things and she fires right up i love my little case it is a great tractor my uncle uses ford 300's so i put some more coler on the farm thanks for the help
jerry s
JRT
11-26-2007 21:03:42
Something is wrong if it won't start easy. I have one that I use in the winter to split wood with a pto type wood spliter. Sits out in the rain and snow all winter hooked to the spliter. All I do is turn on the gas, choke it, and about 3 or 4 turns it will start no matter what the temp. is. I have split wood with it for about 15 years. I do put it in the barn in the summer though.
Glenn F.
11-26-2007 10:35:26
There's no reason that little tractor shouldn't pop right off in the coldest of conditions. They don't require much maintenance either. We live in NE WI, and for YEARS didn't have a shed of any kind. Keep good, properly adjusted plugs, properly adjusted lifters, "winter oil", clean battery connections with heavy cables, and you'll be jump starting/pulling everyone in the neighborhood on cold mornings.
That said, every engine has it's own personality, and will take a little getting used to.
Glenn F.
Goose
11-26-2007 10:12:31
Between my father and I, we had two different VAC's. Without any special precautions, other than a good tune-up, they were two tractors we could count on to ALWAYS start in the winter.
We often belted them to bigger tractors as a "starting unit" to get a bigger tractor started.
Gene Dotson
11-26-2007 07:07:31
Many things you can do to make it easier to start in cold weather. First, use a lighter weight oil. like a 5W20 or 10W30. Make sure the battery is charging to full capacity. Be sure the battery and starter cables are clean and heavy enough to carry the load. A short warmup with a battery charger will quick;y bring the battery to full power. Richen the power mixture on the carburetor to compensate for more dense air. Use a hotter heat range spark plug to get hotter spark. Be sure the ignition is clean and properly adjusted. Any heat that can be applied will help for quicker starts and can be by external forced air heat or a coolant heater in the water jacket or radiator hose or engine oil.
Use of fresh fuel and careful use of the choke are important....Gene
GeoM0
11-26-2007 05:55:10
MY 51 VAC START AND RUN GOOD AFTER I CONVERTED IT TO 12V.
I HAVE TO WATCH THE AIR CLEANER, FILLS WITH WATER AFTER RAIN OR SNOW.
Paul f
11-26-2007 05:19:43
Both of my Cases (DC and VAC) like to be warm to work. They both fire up quickly when cold but don't ask them to do anything until they warm up. Heck my DC stalled herself trying to back out of the shop to plow some snow, She couldn't lift herself over the tire chain cross links. I have some cardboard that covers most the radiator and I let her warm up for a few minutes before I try to move any serious snow. In the summer the VAC has to be warmed up before you try to use the 6ft finish mower in any thick grass or she will stumble and die.
Robert Huntress
11-26-2007 04:08:00
Have you considered a jacket water heater? If you park your tractor near an electrical source, it would keep your jacket water warm while the engine is not running. They are not much money, and are very easy to install.
patsdeere
11-25-2007 21:32:31
Just think about how old it is. Now place your self in the same age range and sit out in the cold for a period of time. I bet you will be cranky too.
They can be a little tough to start when cold. A little starter fluid can never hurt.
