801B Exhaust Manifold Holes
larryNeohiocase
11-25-2007 08:29:16
So can anybody tell me the purpose of the round holes in the bottom of the exhaust manifold on cylinders 2 and 3 on my 1959 801B diesel? Should there be some type of plugs in them or are they for some sort of sending unit for a guage that I haven't figured out yet?
Thanks,
Larry
Jim B
11-25-2007 18:26:52
 Re: 801B Exhaust Manifold Holes in reply to larryNeohiocase, 11-25-2007 08:29:16
Yes, to let rain water out...
But a word of caution...
If the Ol' girl is kept outside for several years (especially if little used) without a working raincap or tin can over the exhaust pipe those holes may rust over and not let the water out and then it runs straight into the cylinder. This is one of the main causes of seized pistons on machines that aren't under-roof.
We've bought and saved a 700 and a 830 when "stuck" and both had the manifold drain holes plugged with rust.
Eldo case
11-25-2007 11:56:31
To let rain water out!!!!
larryNeohiocase
11-27-2007 05:57:47
 Re: 801B Exhaust Manifold Holes in reply to Eldo case, 11-25-2007 11:56:31
Well that is very interesting. So it will be stored under roof and there is a functioning rain cap can I plug those holes? I really have an issue with the exhaust leak noise...
And thanks for the information guys.
Jim from Calif
11-27-2007 09:08:40
 Re: 801B Exhaust Manifold Holes in reply to larryNeohiocase, 11-27-2007 05:57:47
I pluged the exhaust manifold holes on my 58 Case 800. I just cleaned the holes well, and then filled them with JB Weld. It has worked great for the past 3 years for me.
larryNeohiocase
11-27-2007 09:25:46
 Re: 801B Exhaust Manifold Holes in reply to Jim from Calif, 11-27-2007 09:08:40
Jim,
I was thinking about JB Weld also. You didn't happen to notice if the holes were threaded did you?
Thanks,
Larry
Jim from Calif
11-27-2007 12:32:08
 Re: 801B Exhaust Manifold Holes in reply to larryNeohiocase, 11-27-2007 09:25:46
The holes were not threaded on my manifold..
