400 project
Jim McVay
11-24-2007 21:13:31
As I posted earlier I'm restoring a 400 that required an engine and trans-axle rebuild. I took it for a drive today. In 8th gear it went 24 MPH. I need to replace the gear shift boots and install the hood, grille and nose. I also am adding an electric tach that feeds from the alt. I also added some 930 steps so I can mount from in front of the tires. It also has a 830 seat and a late 730 dual shifter. I also need to work on the hydralics. When its done it will be a one of a kind. All I will need is some fenders.
Gene Dotson
11-25-2007 12:35:02
 Re: 400 project in reply to Jim McVay, 11-24-2007 21:13:31
Jim;
There was a 400 at the Plain City, Ohio show this summer with a 504 turbo engine. Tried an exhibition pull in high gear and smoked the tires. Had stock tires and no weight. Pretty impressive tractor... Gene
comfortking
11-25-2007 06:03:48
Is this a clutch or a COM drive?
Gene Dotson
11-25-2007 07:50:49
 Re: 400 project in reply to comfortking, 11-25-2007 06:03:48
Case-O-Matic came along after the 400. 800 was the first Racine tractor with Case-O-matic... Gene
Patrick Tercho
11-25-2007 04:51:21
Sounds great Jim! Please post pics when you get it finished, I'd like to see it.
