piston sleeve sc case
Albert Stegall
11-24-2007 07:21:53
any one out there have any left over engine parts that are usable?I am in need of 1 piston and 2 sleeves for an SC Case. They are 3 5/8 bore. Thanks Al.
L.Lamp
11-25-2007 21:23:57
 Re: piston sleeve sc case in reply to Albert Stegall, 11-24-2007 07:21:53
Check with Don Livingston. He has new and used parts. He has bearings for rods and can have your old main shells remanufactured to any size you want. I have gotten 6 sets of new mains from him. He's a real nice guy. His e-mail is : [email protected]
Albert Stegall
11-26-2007 06:05:07
 Re: piston sleeve sc case in reply to L.Lamp, 11-25-2007 21:23:57
Thanks for the info. I will check it out. Al.
C. Amick
11-25-2007 18:42:07
Try Dennis Bealer ([email protected]). He is in PA. He sells used parts. I saw a new set of sleeves and pistons in a magazine for $650, if interested.
Albert Stegall
11-25-2007 20:32:21
 Re: piston sleeve sc case in reply to C. Amick, 11-25-2007 18:42:07
Thanks for the info on the sc parts it is very helpful. Al
John Saeli
11-25-2007 09:47:09
2 different 3 5/8" sleeves were used on the SC's depending on the serial #.
Albert Stegall
11-25-2007 10:49:11
 Re: piston sleeve sc case in reply to John Saeli, 11-25-2007 09:47:09
The serial # on my sc case is 4801386sc Thanks Al.
L.Lamp
11-25-2007 08:08:26
If you need a cast iron piston, I have one. I do not have any sleeves.
Albert Stegall
11-25-2007 10:39:31
 Re: piston sleeve sc case in reply to L.Lamp, 11-25-2007 08:08:26
Thanks mine are aluminuma. Mabe some will show up
