case 580B stabilizer mounts
DougM
11-23-2007 09:32:31
This is probably a stupid question but, the stabilizers on the 580B have 2 positions for the base anchor pin, 1 angles the stabilizer back slightly & the other position the stabilizer is straight out from the machine. Under what conditions would you use the straight out position.
Also on the bucket there are 2 positions to mount the cylinder link, where would this second position ( farther back on the bucket) be used.
Dennis/Ohio
11-24-2007 03:16:16
 Re: case 580B stabilizer mounts in reply to DougM, 11-23-2007 09:32:31
Thats a nice option. I have a friend with a 580B I"ll have to check it out. It would be less strain on the stabilizer mounts and you could dig using more power without sliding the tractor.
Bucket holes are for digging a hole with straighter vertical walls (less radius on farthest wall).
Best, Dennis.....
