circulating block heater on case 430
kdok44
11-23-2007 05:43:56
Hello i need a little info on circulating block heaters work. I just installed one on my tractor case 430 the weather here gets really cold. I know it heats the anti freeze and circulates it threw convection. What i dont know is does it heat the antifreeze in the Radiator or just the block. When i plug it in my temp gauge on tractor gets really hot quite fast say 175 in about 5 mins Iam scared i am going to burn the rad hoses. Last question does a case 430 have a thermostat or is it just run wide open thanks for any info...
bradley martin
11-23-2007 10:07:35
 Re: circulating block heater on case 430 in reply to kdok44, 11-23-2007 05:43:56
If it heats that fast you will not have to leave it plugged in overnight. Just plug it in 5-10 minutes before you intend to use it. Your heater must be way oversized.
Gene Dotson
11-23-2007 07:57:26
You won't hurt the radiator hoses. They are designed to function at higher temperatures than the boiling point of anti-freeze. What wattage heater are you running? A 500 watt heater is plenty for this engine and easier on extension cords. A 1500 watt heater draws a lot of current and causes a lot of heat in the plug connection... Gene
kdok44
11-23-2007 11:09:33
 Re: circulating block heater on case 430 in reply to Gene Dotson, 11-23-2007 07:57:26
i got the one recommended to me by the sales person he looked it up. Its actually 1600 watts pretty big i guess but he said thats pretty generic. I was just wondering if it was getting so hot so fast because i have an airlock or something or i know my thermostat must work Or be stuck open because it never over heats while running if anything it usually runs a bit coool. Also when i tested it today its only about -14C which is still pretty warm. And maybe the temp would have dropped if i gave thermostat time to open i think its 180.
DKase
11-23-2007 07:18:25
Antifreeze will circulate in the tractor from the top connection to the bottom. If it goes through the radiator easier than the block that is the way it will go.
bradley martin
11-23-2007 06:31:12
430s have a thermostat.
