Seized brake Disc
Ckerr
11-22-2007 15:34:46
Does anyone have a good idea how to remove a seized brake disc. I have a 580C construction king and am redoing the entire brake system and the last brake disc is frozen on. I tried an air hammer,blow torch,PB Blaster,hammer and chisel. Just about everything but cutting it off. If I need to cut it off what is the best way?
Thanks so much for your time!
CENTAUR
11-22-2007 17:33:21
 Re: Seized brake Disc in reply to Ckerr, 11-22-2007 15:34:46
I hope you will not be offended as I do not know if you know that you will hit the hardest with a low cyclic rate long stroke air hammer.the short stroke high cyclic rate are better for the bodyman to cut body metal as it is easy to control. CENTAUR
CKerr
11-22-2007 19:19:42
 Re: Seized brake Disc in reply to CENTAUR, 11-22-2007 17:33:21
Thanks for the info CENTAUR,
I did not know that. I am willing to try anything at this point.
