430 hydraulics
acdave
11-21-2007 18:54:04
my 430 has draft matic 3 pt but has no control valve for the remote hyd just 2 hyd. lines running out of the hyd case is there something missing here it had a loader with a homemade control valve on it
bradley martin
11-22-2007 03:09:23
 Re: 430 hydraulics in reply to acdave, 11-21-2007 18:54:04
Remotes were optional when these tractors were built so it is possible that yours was one of the few built without it.
R F W
11-22-2007 06:40:05
 Re: 430 hydraulics in reply to bradley martin, 11-22-2007 03:09:23
Bradley My case 430 also only has the two lines out the back can I assume one line is the power line to activate the hyl and the other line is the return line.so hooking up a two way control valve would make it work up and down or in and out, Have a SAFE great day and thank you..Barney
bradley martin
11-23-2007 01:34:14
 Re: 430 hydraulics in reply to R F W, 11-22-2007 06:40:05
430 hydraulics are 2 way circuits and most had 2 valves. The outlets at the rear are 1 circuit and most of these tractors had the 2nd circuit plugged at the valve . The 2nd valve was usually only activated when a front end loader was mounted.
