case engines
new case puller
11-21-2007 16:48:02
Could any one tell me rather a case 451 or 504 diesel block will work in a 910 b tractor,someone told me that 336 gas heads will work on the 504 block,block looks pretty much the same as 377 just about a 1/4 inch wider.if not will a 401 or 451 diesel block work? I dont know if they make a 401 or451 gas.any info greatly appreciated,thanks.
DKase
11-21-2007 19:19:11
 Re: case engines in reply to new case puller, 11-21-2007 16:48:02
The largest engine that will fit in the 900 is a 401 from a 6 speed 930. I have a good block if you need one. Direct injection 401, 401 from an 8 speed, any 451, or any 504 will NOT fit. DK
mh guy
11-21-2007 19:29:46
 Re: case engines in reply to DKase, 11-21-2007 19:19:11
yes i would be interested,how much are you asking and where are you located? thanks.
