case 580k backhoe
jeremy collard
11-21-2007 12:15:09
i own a case 580k which i use on and off, but i have started a new job where everything is komatsu so the controls for the boom and dipper are reversed. what i want to know is, is it possible just to swap the hoses around on the vale block so my case matches the komatsu?? hope someone may offer some advice!
mEl
11-21-2007 14:50:19
 Re: case 580k backhoe in reply to jeremy collard, 11-21-2007 12:15:09
NO!!!!! !!!!! there are secondary reliefs whigh are set at different pressures , the method of changing hoses changes the pressure settings at whch the systems are protected against shock loads or overloads caused by pressure pushed back against the cyls by leverage. I have made new control rods bent to go where they must to change the lever operation to suit the operator. works well and retains the hosing as is
jeremy collard
11-22-2007 11:31:25
 Re: case 580k backhoe in reply to mEl, 11-21-2007 14:50:19
hi thanks for your advice, its pretty much sort of what i thought would be the casebut worth asking! the adaption you have made sounds like a great idea, would you be able to fabricate some controll rods or some drawings?
mEl
11-22-2007 13:51:53
 Re: case 580k backhoe in reply to jeremy collard, 11-22-2007 11:31:25
uncover the control assembly and see where the rods have to go, there are only two that need to be interchanged and they will cross one another. it will be obvious what they will need to look like to hook up. allow enough length to thread the top for the joints / yokes and get the right length at the spool, heat the end up, pound it flat so it is wide enough to drill a hole it it for the spool pin and will fit down in the spool without binding.adjust so the wobble sticks are even and dig.
jeremy collard
01-06-2008 13:09:04
 Re: case 580k backhoe in reply to mEl, 11-22-2007 13:51:53
hi there i have finaly got around to making the new control rods as you suggested and it all works perfectly! many thanks for your advice.
