Case VAO VOMITING
gary case
11-21-2007 07:20:48
have a CASE VAO '48 that when you rev it up it starts discharging anti freeze out the over flow. idleing its ok. just had it running real good and put it to the side for about a month. i fired her right up,ran good then all of a sudden it started puking. i did drain some anti freeze out of the rad and filled it back up with more new anti freeze,topping it off with what i drained out.i never did check out if it had a thermastat or not.
mikefromiowa
11-22-2007 13:54:23
 Re: Case VAO VOMITING in reply to VACLee, 11-21-2007 07:20:48
make sure it has a thermostat in it. Mine did the same thing until I put a thermostat in her. Hasn't lost a drop since.
garys vao
11-23-2007 08:26:46
 Re: Case VAO VOMITING in reply to mikefromiowa, 11-22-2007 13:54:23
thanx Mike, i lost my orginal handle. so i guess i'm going to go with garys vao. it won't go through. tried and enabled cookies,with no luck. anyways going to check that thermastat also. gary
garys vao
11-23-2007 08:22:06
hell-o, what does tis mean? (foam) thanx gary
C. Amick
11-21-2007 17:22:05
 Re: Case VAO VOMITING in reply to gary case, 11-21-2007 07:20:48
Did you mix the antifreeze 50/50? Have you looked in the radiator with it running? Is there a lot of bubbles and foam that's causing the problem?
Keith-OR
11-21-2007 08:30:41
Gary, the over flow tube for the radiator is down inside the radiator. Therefore it will as you call it vomit fluid out untill water and antifreeze is again below the level of the tube.HTH
Don't fill radiator clear up to the radiator fill neck!!
Keith & Shawn(Special Olympic Champion)
