How to pick up an 800 engine
INCase
11-19-2007 18:31:08
What is the best way to pick up a Case 800 4 cyld engine? Both in separating from the tractor and installing it into the tractor? I didn't see a real good obvious place to attach the hoist. Thanks.
INCase
11-20-2007 14:00:38
 Re: How to pick up an 800 engine--since we're on the subject in reply to INCase, 11-19-2007 18:31:08
Does anyone have a trick on removing the COM unit without goofing anything up? I see there is a jig to do this. Has anyone come up with a way without building a fancy jig?
Sherrmann
11-20-2007 14:19:43
 Re: How to pick up an 800 engine--since we're on the subject in reply to INCase, 11-20-2007 14:00:38
I have made a jig to remove a case-o-matic unit.
I looked at the pictures of the Case made unit. Then I made a wooden mockup out of scrap wood, to get the demesions right. Then bought the steel bar, and my father-in-law helped me weld it all together. It worked like a charm, the COM unit slid out nice and easy and went back just as nice(after I replaced all the leaking seals). Right now the jig is just it's sitting on my shelf. If you like I could send some pictures and measurements. I would also be willing to lend it to you,I'm located in central MN.
Bret4207
11-20-2007 11:19:57
 Re: How to pick up an 800 engine in reply to INCase, 11-19-2007 18:31:08
Use your legs, not your back.....
Sherrmann
11-20-2007 05:24:46
When I removed the engine off my 830, I took two short lenths of chain and bolted them to the four valve cover studs. This way I could balance the load by adjusting the lenth of either chain.
Jim B
11-19-2007 21:10:22
Our Manual shows a piece of heavy bar-stock attached to the 4 studs which hold down the valve covers. Two lifting eyes are in-turn attached to this bar. The lifting points apparently are located so as to balance the weight.
INCase
11-20-2007 05:08:22
 Re: How to pick up an 800 engine in reply to Jim B, 11-19-2007 21:10:22
Thanks. Wow, I would not have thougth of using those but I as would not have figured those were strong enough to hold the engine up.
