case series difference?
ronny
11-19-2007 11:07:19
whats the are the differences between the case "300" 300 series and "350" 350 series. I am looking to buy one and need some more info on them and where i can find one.
ronny
11-21-2007 10:01:21
 Re: case series difference? in reply to ronny, 11-19-2007 11:07:19
Thanks for the info, I will continue my search for the tractor.
BarryfromIA
11-20-2007 17:29:58
 Re: case series difference? in reply to -�-, 11-19-2007 11:07:19
The 350 will have a plate bolted to the maifold side of the block as this is the same sleeveless engine used in the later 500 and 600. A 350 has a 3 bolt starter and the 3 point mounts to axle with castings instead of the steel parts used on the 312.
30 Series
11-19-2007 19:27:15
Along with a bigger engine the 350 had more crop clearance with the taller tires and bigger cast spoke wheels later used on the 500B/600B series and the 630s. Point of interest, there was a model 300 with these wheels and tires that did not have the bigger engine. It was called a high-clearance 300.
Triplerange
11-20-2007 12:54:47
 Re: case series difference? in reply to 30 Series, 11-19-2007 19:27:15
Yep...you're right. that was the 312 that my dad has. Same wheels as my 630.
C. Amick
11-19-2007 14:15:47
The engine size is probably the biggest difference. The 300 Series has the 148 cubic inch engine and the 350 Series has around a 160 cubic inch engine. The 350 Series is much more rare. It was only made one year and it is a favorite of tractor pullers.
