730 fuel tank leak
geoids
11-19-2007 06:47:28
I'vet got a leak on the bottom of my 730 gas tank. Is the fitting that the fuelbowl/filter screws into, threaded into the tank? or is there a nut on the inside? How do you tighten it if you need to replace the rubber seal?
JRT
11-19-2007 21:59:11
 Re: 730 fuel tank leak in reply to geoids, 11-19-2007 06:47:28
If it is leaking around the threads of the sediment bowl, all you have to do is take the gas line loose from the sediment bowl and turn the entire sediment bowl assembly until it is tight. There is no rubber gasket there. If it is leaking around the glass on the bowl you can get a new rubber gasket at NAPA or somewhere like that.
caseAlot
11-19-2007 19:11:12
According to parts manual, If it is a gas tractor with a glass sediment bowl, there is no nut, it is just threaded onto the tank, What rubber seal are you refering too?
