Case 530
Doug F
11-18-2007 06:43:20
What motor choices do I have for a Case 530 Constuction King Gas ? Will a 660 combine motor work?? Thanks
Doug F
11-19-2007 16:34:30
 Re: Case 530 in reply to Doug F, 11-18-2007 06:43:20
Well here's the deal I know where there is a 530 loader tractor with a blown engine. I have 2 good combine engines that I was hoping would work. Just going to use it on the farm. not a show tractor. Thanks for the help!
bradley martin
11-19-2007 02:11:01
I am mistaken then...I have a sales brochure from l966 that shows the 660 with a 20l gas and a l88 diesel option.
casefarmer
11-18-2007 17:43:20
I have a 530 gas that I put a Case 660 gas combine engine in. It bolts right on after the fly wheels are changed over. The only problem I had was the 660 motor is 1 1/2 inches longer which means a new hood and modified throttle linkages. The 660 motor was made by case and is 201 cubic inches.
JGarner
11-18-2007 19:12:02
 Re: Case 530 in reply to casefarmer, 11-18-2007 17:43:20
The 530 diesel hood would probaly work on the 660 engine. The diesel is 188 cid engine but the gasser is 159 cid and a bit shorter.
BarryfromIA
11-18-2007 17:02:10
 Re: Case 530 in reply to VAC newbie, 11-18-2007 06:43:20
In Iowa the 600 and the 660 combines had case engines and the 960 had a MoPar slant six.
bradley martin
11-18-2007 16:01:03
The 660 combine did not have a Case engine so I doubt very much that it would bolt in without major modifications.
Jim B
11-18-2007 19:29:45
 Re: Case 530 in reply to bradley martin, 11-18-2007 16:01:03
Yes they did... They were Case 188 Gas Engines.
Doug F
11-18-2007 16:56:14
The motor that I took out of the 3 660 combines were Case 188.
Tom (Ks)
11-18-2007 12:28:55
The 530 gas is a 159, a 630 gas is a 188, then there is a 207. I can't tell you which engines interchange.
