CASE 801B
Tony Z
11-17-2007 16:31:14
What is the difference between the Case 800 and the Case 801B? Does anyone know? Did the 801B come standard with a three point? Just wondering because I am looking at an 801B.
Thanks,
Tony
Tony Z
11-19-2007 06:31:45
 Re: CASE 801B in reply to Tony Z, 11-17-2007 16:31:14
Thanks for taking the time to answer Gene. I really appreciate the info. One more question, I am assuming when you say to make sure the transmission operates well, that means all the gears work and it shifts properly. If there is something else I need to look for please expound. Thanks.
Tony Z
Gene Dotson
11-17-2007 17:11:12
801B is the diesel row crop version of the 800 series. Spark ignition versions were 810, 811 or 812. Deisel versions were 800, 801 and 802. They were made in standard, row crop and utility. The ID plate will have this number, but the decals will all read 800. B series were made in 1959 with the inline German Bosch fuel pump... Gene
larryNeohiocase
11-19-2007 04:16:44
 Re: CASE 801B in reply to Gene Dotson, 11-17-2007 17:11:12
Gene,
I'm sorry but i have to add/correct your post. I have a 1959 801B and it has an American Bosch PSB injection pump.
Larry
Tony Z
11-18-2007 07:43:23
Thank you for your reply. I appreciate it very much. As far as the fuel pump and engine, if it had to be repaired, is it difficult to get parts for? I need a work tractor so I am looking for a tractor I can keep and maintain for many years.
Thanks,
Tony
Gene Dotson
11-18-2007 18:08:33
 Re: CASE 801B in reply to Tony Z, 11-18-2007 07:43:23
Tony;
Not much maintenance required on the fuel system. The German Bosch has a drain plug to drain the oil and replace with new engine oil at oil changes. Fuel injectors are the same used on all Power Cell engines and same as many Allis Chalmers and Minneapolis Moline diesel engines. There are still after market engine parts available, but these engines are pretty dependable and long life. If you live in a cold climate, a block heater will be a good investment and warm the engine prior to starting. Try to avoid ether starting if at all possible.
Be sure the Case-O-Matic works properly and learn how to properly operate it. They are a dependable transmission if treated properly, but a costly repair... Gene
Tim in New York
11-19-2007 09:43:25
 Re: CASE 801B in reply to Gene Dotson, 11-18-2007 18:08:33
Hey Gene - any idea where to get a block heater? My 701 has a 3/8" plug right behind the oil filter that my manual says is for a block heater up to 5" long. Where in the heck can you find a block heater with that small of a diameter?
Tim
