WET CLUTCH 504
LP PULLER
11-16-2007 09:43:42
HAS ANYBODY PUT A 504 BLOCK IN A WET CLUTCH 900 I'M GETTING CONFLICTING STORIES WETHER IT CAN BE DONE
DKase
11-16-2007 16:40:50
 Re: WET CLUTCH 504 in reply to LP PULLER, 11-16-2007 09:43:42
I do not believe the bell housing will bolt up.
case900puller
11-17-2007 17:45:40
 Re: WET CLUTCH 504 in reply to DKase, 11-16-2007 16:40:50
the 504 block will not bolt up to a 900. The bell housing is differant. The 504 will bolt up to a 930 with the 8 speed transmision but not a 930 with the 6 speed. I have looked ito this as well and found that you can rebuild the 900 engine to 504cubic inches but never hade any luck on how to do it.
Travis m
11-17-2007 18:12:46
 Re: WET CLUTCH 504 in reply to case900puller, 11-17-2007 17:45:40
4 5/8 sleeves and pistons
