vac belt pully hydraulic pump
young tractor
11-15-2007 10:25:29
I"m looking to rebuild the hydraulic belt pully pump on my vac cas. What parts do I need? And can anyone outline how to do it. Are the parts hard to get? I am new to the vac and am trying to get my grandfather"s tractor rebuilt. Thanks for any advice.
C. Amick
11-17-2007 08:08:29
 Re: vac belt pully hydraulic pump in reply to young tractor, 11-15-2007 10:25:29
I've never seen one of these pumps wear out. Does it have oil in it? It could have been damaged, if it was run dry. You should be able to find a used one in good condition.
BLR
11-16-2007 22:47:37
Are you positive it needs rebuilding? There is a stop bolt that disengages it from the belt pulley shaft cam that drives the pump on the top side of the pulley housing. Back that bolt out to engage the pump. Also, If the pump hasn't been used in a while it may also need to be primed, and there is a petcock on the pump itself for that purpose.
Joe (Wa)
11-15-2007 15:02:41
Go to this link, hi-press system starts on page G7 I1. Click on the page to enlarge.
Joe
