Anyone have Case 930 manual on pdf?
Joe Stewart
11-15-2007 04:45:56
I just bought a Case 930 in marginal condition. I"d like to start tinkering with it and wanted to know if anyone had any of the manuals in a pdf file? Or if anyone had a paper copy for sale. Thanks Joe Stewart
CKRICHARD
11-15-2007 14:50:57
 Re: Anyone have Case 930 manual on pdf? in reply to Joe Stewart, 11-15-2007 04:45:56
Joe that is just for the engine, 401 cid and engine serial number . The serial number for the tractor should be on the left down below the dash.
jcmarleau
11-15-2007 09:13:54
I do have part manual for the 930 for sale but will need your serial number as there is three different manual depending on your serial number. jc.
Joe Stewart
11-15-2007 09:40:14
 Re: Anyone have Case 930 manual on pdf? in reply to jcmarleau, 11-15-2007 09:13:54
Thanks. Model 401 Serial 2181511. Diesel. Anyone know what year this beast was manufactured?
Gene Dotson
11-15-2007 12:20:47
 Re: Anyone have Case 930 manual on pdf? in reply to Joe Stewart, 11-15-2007 09:40:14
Joe;
Are you asking about another tractor here? The 401 would have been built between 1955 and 1957. Serial number should be 7 digits beginning in 8. 8060001 was first 400 built... Gene
Joe Stewart
11-15-2007 12:57:44
 Re: Anyone have Case 930 manual on pdf? in reply to Gene Dotson, 11-15-2007 12:20:47
I copied those numbers off of an aluminum plate on a casting on the right side of the engine, up near the front of the motor. The aluminum plate says model 401 and the next number on the plate is the one that I put in my prior post. The hood says Case 930. Is there another spot that I can look for a serial number or is this it? Maybe I copied down a partial number. I'll have to look again this saturday when I go out to the property (on other side of town,where the tractor is stored). Thanks for all the help! J. Stewart
Gene Dotson
11-15-2007 18:19:52
 Re: Anyone have Case 930 manual on pdf? in reply to Joe Stewart, 11-15-2007 12:57:44
Joe;
This is the engine size and serial number. The tractor serial number should be on a tag on the right side of the instrument cowl near the right side of the fuel tank if it is an early model. Comfort King models made 1965 and after will have the fuel tank behind the seat.
Basically 3 versions were made. Early models had 6 speed transmission, mid models used 8 speed transmissions and later Comfort King tractors had 8 speeds, rear fuel tank and the operator platform was moved forward and higher... Gene
Joe Stewart
11-16-2007 04:21:29
 Re: Anyone have Case 930 manual on pdf? in reply to Gene Dotson, 11-15-2007 18:19:52
Thank you CKRichard and Gene! Mine has the fuel tank behind the seat. I will look in these locations for the ID tag.
JGarner
11-15-2007 05:30:20
Watch ebay for paper copies. There are 930 manuals on it in the Antique Tractor/Case site right now. Easiest way to find these manuals is to search in the Business and Industrial section for 930 Case manuals. This narrows your search down a bunch.
JGarner
