Case magneto
Rick/mn
11-14-2007 07:34:19
I have a Case air cooled 4 cylinder engine - probably off a A-6 combine that I am trying to get running. Is complete and not stuck so should run. Haven't yet pulled the plugs and checked compression. Has a Case magneto that does not seem to have any spark. Are parts avilable if needed, can the "mag fixers" that advertise in various magazines fix these things etc? I have found no service literature yet for the engine or mag. Any help out there? Thanks, Rick
James Herrman
11-14-2007 20:51:15
 Re: Case magneto in reply to Rick/mn, 11-14-2007 07:34:19
Not sure what year, but on my 1931 CC it uses a base mount and I substitued a Fairbanks Morse FMJ base mount. But if yours is a flange mount this info will not help. Understand that Case mag parts are hard to obtain. Hope this will be of some help to you.
Bob
11-14-2007 19:53:19
If you can't get it fixed, at least right away, an IH H-4 magneto (a VERY common mag) will bolt right on, and get the engine fired right up.
It depends upon what you want... easy availablity (including parts) or something that is "correct".
Third Party Image
Rick/mn
11-14-2007 19:17:02
Thanks for the replies, Walt, it does not look like either of the mags on the cover of that manual. I can't see a model # on it any where. Looks more like the upper one but does not have the upper cover on the front half - only the cap where the plug wires go in detaches with screws
Walt Davies
11-14-2007 10:24:43
If its a case Magneto its most likely one of these two on the web-page.
Walt
C. Amick
11-14-2007 09:40:32
The most common probem with magnetos is dirty points. Try cleaning the points with really fine sand paper or a fingernail emory board. John Saeli ([email protected] or 315-585-9826)used to sell rebuilt magnetos, not sure that he still does?
John Saeli
11-15-2007 05:23:28
 Re: Case magneto in reply to C. Amick, 11-14-2007 09:40:32
Haven't had any mags for a while, but the most common problem is corrosion on the inside. I'm sure many good CASE Mags got tossed & they only needed a good cleaning & setting.
Bob Schmidt
11-14-2007 08:10:15
Check out Mainly Magnetos web site. Did a great job on my JD model B.
