case 310 dozer transmission questions
jim trott
11-13-2007 21:23:02
Have trans problem looking for help,main shaft is loose moves up and down and side to side,shaft is not broke.There is a piece behind gears that is broke don't know if it is bearing or part of the casing it has rough edges.Before it would move forward and backwards but wouldn't go all the way in gear,when try to move it would lock both tracks up,take pressure of, it would release.
CHinNY
11-14-2007 01:41:08
 Re: case 310 dozer transmission questions in reply to jim trott, 11-13-2007 21:23:02
Best to take it out and tear it down by now you it may have more worn or damaged parts inside. I have everything you need to rebuild that tranny. New and used Gears,shafts a bearing and seal kit new reverse idler shaft and bearing,manuals etc.... Email me and i will send you my web site.
