VAO
watsonsgotit
11-13-2007 17:40:30
I looked at a tractor recently. I believe it may be a vao with eagle hitch. How do you tell a vao from a vac-14? The front end did not look proper. It had a cast wishbone type front end? What should be proper?
VACLee
11-13-2007 17:51:38
 Re: VAO in reply to watsonsgotit, 11-13-2007 17:40:30
The cast axle would be correct for a late model VAO. It would actually be a VAO 15. The steering column is shorter that a 14. Also the floorboars are lower and the gear shift is angled to the side somewhat instead of to the front.
watsosngotit
11-14-2007 16:10:11
 Re: VAO in reply to VACLee, 11-13-2007 17:51:38
Yes the steering column is short. However it has the early style steering with the drag link. I am wondering if the front axle could have came from a d or a s model. It does have the low platforms. By looking at the brakes and the torque tube I would think it would have to be a 51 model. It did contain the filter in the torque tube and has drum brakes. Does this make sence or is this just something cobbled together?
