Case CC carb problems
tractorhank
11-13-2007 15:16:36
I have a 37 or 38 Case CC unstyled with carb problems. I overhauled the carburetor very carefully only to find it leaking gas once it was turned on. I took it apart and discovered float was leaking and sinking. Tried to repair float but have not had a lot of luck. The tractor runs kind of rich and spits a little gas out of the drain hole on the bottom of the carb intake. Any idea where I can find a float for this zenith carb #8964. It is a double float or any better ideas on repairing it. HELP!!
Jim Mitteer
11-14-2007 03:30:48
 Re: Case CC carb problems in reply to tractorhank, 11-13-2007 15:16:36
I am pretty sure McDonald Carb and Ignition has your float.
