DC Wide Front
Old Iron Larry
11-13-2007 08:36:53
I am converting my DC to an adjustable wide front. What is the difference in the 2865AA arm for the wide front and the A255AA arm for the tricycle.
Don Rudolph
11-13-2007 17:09:34
 Re: DC Wide Front in reply to Old Iron Larry, 11-13-2007 08:36:53
t depends on what year the adjustable front end is. They are all the same I believe except for the arm that comes off the center spindle. The late models had a short arm that worked with the curved long arm and the early models had a longer version that worked with the straight arm. You also have to have the corresponding drop arm from the steering shaft. I had a short drop arm and a longer spindle arm and it took about 15 turns of the steering wheel to get the front end to turn. I had to cut about 2 1/2 inches out of the spindle arm to make it work as it is impossible to find the later model short spindle arm. I hope this makes sense to you. Don
grapefarmer
11-13-2007 09:53:08
I am in the process of doing the same thing. I was hopping, I could just flip the steering arm over. The rod coming from the arm to the front end may have to be shorted also. I will be working on this over the weekend and I will take some pictures.
-Dave
Merdie
11-13-2007 13:00:24
 Re: DC Wide Front in reply to grapefarmer, 11-13-2007 09:53:08
I have looked into putting one(wide front) on my DC. I beleive you both probly have the newer curved steering arms. Wide front will take the striaght arm. The 2 arms will not interchange for the front pivit is longer on the striaght arm, also the key way is in a diffrent spot. ( on the front post).
