SC Magneto
Ken Christopher
11-13-2007 05:42:17
Hello All. Was going to assemble the SC enough to try to get it running before I paint it just to make sure I got it together right. Was trying to get the magneto ready to fire on #1 last night and every-other time I click over the impulse I get a spark. The tractor ran pretty good when I removed the magneto-no misses or anything. The magneto was re-done about 4 years ago, but probably doesn't have over 100 hours on it. I am clueless as to what could have gone wrong. I drove the thing home 10 miles and not one hiccup on the way. Tore it all down that week, now this is what I got. Stuck and troubled..... ..... .
iluvcase
11-15-2007 18:58:53
 Re: SC Magneto in reply to Ken Christopherson, 11-13-2007 05:42:17
You will have to pull the distributor cap and check to see where the distributor disk (rotor) is pointing. If it's not at number one you will have to turn it until it's there...assuming you have the rest of your tractor gears timed correctly you should be on your way. After i posted your reply i remembered that my SC 4-JMA mag also fired every other time just as the L CMA mag did. I pulled the caps on each mag. to be sure i was on number one cyl.....each tractor runs fine. After you're set on number one cyl. you will still have to zero the 3/16 in. hole in the flywheel inspection port hole and adjust the mag. in the slots to fire at this time.
iluvcase
11-13-2007 16:05:05
Hi Ken: I had the same problem on a CMA mag for my "L". I took it to the local magneto repair guy to have it checked out. He bolted it up to the test stand and gave it the works. It would shoot a spark at least 3/8 of an inch. He told me Case mags are unbelieveably hot and that there was nothing wrong with mine and he was'nt going to touch it. I bolted it on to the ol' girl and he was right! Why they spark every other time i do'nt know....i would bolt it on and try it before you give yourself fits over maybe nothing. The Case mags rarely give trouble if kept sealed.
Ken Christopherson
11-14-2007 05:45:26
 Re: SC Magneto in reply to iluvcase, 11-13-2007 16:05:05
Ok, so if there is nothing wrong with it..... I still need to find out how I can find the right impulse. Do I just throw it in with it doing every other, and ready to fire? I don't want to risk igniting on the wrong stroke and put a whole in the piston or burn a valve or anything. I guess there is only one way to find out. (I'm not even sure if I got the cam/crank/and governor timed correctly. I had to do it by checking to see where the valves were while rotating the engine over, then place the governor in with the gear at 25 degrees past counter clockwise rotation. I tried using the punch marks on the gears, but nothing was working together when I was giving it "test-turns".
Walt Davies
11-13-2007 08:07:17
Try this site is has the complete manual for both Case magnetos you can download and print it out for future use.
Walt
