old case two way(or something) plow
combinekid
11-10-2007 23:31:34
Ok I'm a bit curious what I found the other day. I was custom fumigating on a farm the other day when I spoted some plow molbords sticking out of the weeds at the edge of this farmers field. As always rusty old iron catches my eye so I had to check it out. What I found was a two bottom case plow unlike any I had ever seen It had two rubber tires directly across from each other with the plow bottoms in the middle. It then had two more plow bottoms that were upside down in the air. The plow was drawbar pulled. This would tell me that its a roll over plow but it does not apear that it rolls over on a pivot like the modern 3pt plows do. Just curious if anybody could explain to me how it worked
